HOUDINI_OPNAMESPACE_HIERARCHY
Hey. Did anyone experience problems with HOUDINI_OPNAMESPACE_HIERARCHY ? I used this variable before and don't remember that i had any problems with it, however i can't make it work in latest build:
https://www.sidefx.com/forum/topic/37903/
Having op::0.1 and op::0.2 and HOUDINI_OPNAMESPACE_HIERARCHY = "op::0.1" i always get op::0.2 created by default.
https://www.sidefx.com/docs/houdini/assets/namespaces
Does the behavior of HOUDINI_OPNAMESPACE_HIERARCHY  changed recently?
Thanks to SESI support, i figured out that ambiguous name resolving requires you to  specify operator context, like this:
Sop/opname::0.1
If you confident that opname is a unique name, you can do this:
*/opname::0.1
If you have namespace you can leave it, or replace with *:
*::*/opname::0.1
By default all namespaces are displayed in TAB menu. This can be changed in preferences: Edit > Preferences > Shelves and Tab Menu
