PRM_Template set default visability to hidden
I have a few PRM_Templates I need to hide and unhide based on the tools ui.
I can get the functionality I want using enableParm() and setVisibleState() with evalInt() in cookMySop. BUT that only works once the sop node has been cooked/connected. so if i drop down a newly created node all the PRM_Templates are showing, how do i set them to hidden initially?
Also would I need to use updateParmsAndSpareParmsFlags()? Not sure when I would need to call that function
Cheers
bool SOP_YourWhosInTheFloosNode::updateParmsFlags() {
    enableParm("pramName", false, -1);
    setVisibleState("pramName", false, -1);
    return true;
ok looks like you have to override the updateParmsFlags()
http://www.sidefx.com/docs/hdk15.5/_h_d_k__op_basics__overview__parameters.html#HDK_OpBasics_Overview_Parameters_Disabling_Hiding
didn't see that page
Edited by Alex Lombardi
