MrBajt Posted December 20, 2016 Share Posted December 20, 2016 Hello, For the sake of understanding perlin noise (and due to a little downtime during the holidays) I tried to implement a very simple approach to the perlin noise purely in VEX. I'm just a beginner in coding, so maybe this won't work at all, but for the life of me I can't seem to find a solution. Here's my code: float perlin(vector pos;vector freq) { float xi = floor((pos.x/freq.x)); float xmingridpos = xi*freq.x; float xmaxgridpos = xmingridpos+freq.x; //define a grid in x-direction float zi = floor((pos.z/freq.z)); float zmingridpos = zi*freq.z; float zmaxgridpos = zmingridpos+freq.z; //same in z-direction vector randvec1 = normalize(set(random(xmingridpos,40),0,random(zmingridpos,400)))*freq.x; //assign each corner of the cell a random vector vector randvec2 = normalize(set(random(xmingridpos,80),0,random(zmaxgridpos,800)))*freq.x; vector randvec3 = normalize(set(random(xmaxgridpos,120),0,random(zmingridpos,1200)))*freq.x; vector randvec4 = normalize(set(random(xmaxgridpos,160),0,random(zmaxgridpos,1600)))*freq.x; vector g1 = pos-set(xmingridpos,0,zmingridpos); //calculate the distance between the point in question and the grid corner vector g2 = pos-set(xmingridpos,0,zmaxgridpos); vector g3 = pos-set(xmaxgridpos,0,zmingridpos); vector g4 = pos-set(xmaxgridpos,0,zmaxgridpos); float res1 = dot(g1,randvec1); //dot product between the distance vector and the random vector float res2 = dot(g2,randvec2); float res3 = dot(g3,randvec3); float res4 = dot(g4,randvec4); float u=fit(pos.x%freq.x,0,freq.x,0,1); //where the point is in relation to the corners of the grid float v=fit(pos.z%freq.z,0,freq.z,0,1); float temp1 = lerp(res2 ,res1,v); // interpolate the values float temp2 = lerp(res4 ,res3,v); float result = lerp(temp2,temp1,u); return result; } I just wanted the x and z coordinates for simplicity. I'm reading through some tutorials (http://flafla2.github.io/2014/08/09/perlinnoise.html), but he implements a variation (i believe the simplex noise). I just tried to copy what is said in the introduction in the article above. As I have zero clue about what to do, and if anyone is interested, I would like some insight to understand the inner workings of the perlin noise Kind regards, Bajt Quote Link to comment Share on other sites More sharing options...
