Mario Marengo Posted May 31, 2005 Share Posted May 31, 2005 Hey all, I'm a little unsure about one of the UT_KDTree members, and would appreciate some clarification if possible... The name given to the pure virtual function: virtual fpreal const *getP(int ndx) const = 0; seems to indicate that what's expected is a const pointer to the first float in some positional ("P") type whose data is stored as a contiguous array of fpreal's (presumably UT_Vector3 or UT_Vector4 data). But I intend to use the kd-tree with a 6-dimensional split (3 for position P, and 3 for normal N) -- or maybe even 8; not sure yet --, and so now I'm starting to wonder if what is *really* expected as a return from getP() is a pointer to (at least) 'dim' fpreal's. Implying that 'P' stands for a "positional" value in a space with 'dim' dimensions (in my case 6, and not the 4 of UT_Vector4). I'm just organizing my data at the moment, so I haven't put it to the test yet. For the moment, I've decided to keep my kd-tree related vars (P and N) in contiguous storage just in case my suspicion is correct, but I could simplify some things if this requirement didn't exist... so I thought I'd ask TIA for any hints. Quote Link to comment Share on other sites More sharing options...
crunch Posted May 31, 2005 Share Posted May 31, 2005 Hey all,I'm a little unsure about one of the UT_KDTree members, and would appreciate some clarification if possible... The name given to the pure virtual function: virtual fpreal const *getP(int ndx) const = 0; seems to indicate that what's expected is a const pointer to the first float in some positional ("P") type whose data is stored as a contiguous array of fpreal's (presumably UT_Vector3 or UT_Vector4 data). But I intend to use the kd-tree with a 6-dimensional split (3 for position P, and 3 for normal N) -- or maybe even 8; not sure yet --, and so now I'm starting to wonder if what is *really* expected as a return from getP() is a pointer to (at least) 'dim' fpreal's. Implying that 'P' stands for a "positional" value in a space with 'dim' dimensions (in my case 6, and not the 4 of UT_Vector4). I'm just organizing my data at the moment, so I haven't put it to the test yet. For the moment, I've decided to keep my kd-tree related vars (P and N) in contiguous storage just in case my suspicion is correct, but I could simplify some things if this requirement didn't exist... so I thought I'd ask TIA for any hints. 18510[/snapback] UT_KDTree should be able to handle up to 254 dimensional positional data. I believe that virtual fpreal const *getP(int ndx) const = 0; Returns a pointer to the offset of the contiguous array of floats. Thus, you could have: class MyElement { public: fpreal myP[6]; }; class MyTree : public UT_KDTree { public: MyTree() : UT_KDTree(6, 100); virtual const fpreal *getP(int idx) { return myData[idx].myP; } private: MyElement myData[100]; }; The only thing that the KD tree requires is that you have the positional data contiguous in memory (i.e. an array of fpreal types). I hope this helps. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 31, 2005 Author Share Posted May 31, 2005 UT_KDTree should be able to handle up to 254 dimensional positionaldata. I believe that virtual fpreal const *getP(int ndx) const = 0; Returns a pointer to the offset of the contiguous array of floats. 18512[/snapback] Thanks Crunch! Yeah.. the more I thought about it, the more that seemed to be the only thing that made sense. Too bad this will mean some duplication of data just to make it "kd-tree compatible", but I guess that's unavoidable... bye bye pointers... Thanks again! Quote Link to comment Share on other sites More sharing options...
