Create Minimum Distance for Connect Adjacent Pieces node?
lucasridley
I'm following along a tutorial, and basically want to wrap a model I created in a wireframe network with scattered points, so I'm using the spray paint to lay them out and connect adjacent pieces to connect them.
My question is on the connect adjacent pieces node: It gives you the ability to set maximum distances, but not minimum. How and what would I adjust about the node to allow me to set a minimum distance?
My problem is that there are too many point close together connecting and I want a minimum distance set to prevent a jumbled mess of points connecting. I'm a total newb here and with houdini so any help is greatly appreciated! Thanks!
  • 1 month later...
