Hdk Compiles But Won't Load
Hello again,
So, on Suse9.1 I can now compile but the .so will not load. I get:
Houdini DSO - error on '/home/pbowmar/houdini7.0/dso/showparms.so'
/home/pbowmar/houdini7.0/dso/showparms.so: failed to map segment from shared object: Operation not permitted
What does that mean, and how do I stop it? :)
Note: The exact same code compiles and runs OK on Redhat Fedora Core 1.
Cheers,
Peter B
not that it's much help, but on our two Suse machines, when I need a custom sop, I compile under Redhat9 & copy the dso over.
I'm sure someone has a real fix, but as a band-aide, that works.
FYI: I've had great luck under Ubuntu re: Houdini & HDK. I don't know what you're trying to get out of Suse & this is not place for which Linux is better, but... as an FYI. ;)
