Select specific numbers of points based on height
Farmfield
This just gotta have a simple solution, just couldn't think of a straightforward way to solve it. I'm looking for a division independent way to group N amount of random points from the bottom (P.y == 0) and an equal amount of random points from the rest (@P.y > 0). And sure, you can solve this several ways, using a couple of SOPs, but I'm looking for something like a single expression in a group- or wrangle SOP, if that's even possible.
The only one-node-solution I can think of is splitting the bottom and other points into arrays in a wrangle SOP and choose N amount of points from each - but I instinctively feel there's gotta be a really simple solution I'm missing, it's my default mode, missing the obvious... :D
grid.hiplc
It's easy, if you use HOM instead of Expression:
import random
n = 100
bottom = []
rest = []
for p in hou.pwd().inputs()[0].geometry().points():
    if abs(p.position()[1]) < 1e-6:
        bottom.append(p.number())
    else:
        rest.append(p.number())
random.seed(12345)
random.shuffle(bottom)
random.shuffle(rest)
return ' '.join(map(str, bottom[:n] + rest[:n]))
Result:
complex_pattern.hipnc
It's mostly the same, you need to add unselected points to the rest list before sorting it randomly:
import random
n = 100
bottom = []
rest = []
    else:
random.seed(12345)
rest += bottom[n:]
