DannyCT Posted February 1, 2017 Share Posted February 1, 2017 Hi there, First time post here. I'm relative new to Houdini and I really love already it but there are some things that (probably) are really simple but I just can't figure out. I must admit that I have very little experience in expressions and python (which I'm already working on) but for something I'm currently working on I'd hope to have some help before I get proficient enough in that. I have a volume source which emits in the Y axis and I wanna use the gas disturb fields but only on the voxels that are being emitted for the first second, after that I want other microsolvers that I have in the scene to take over. What kind of expression should I use for that? Should I first add some kind of life-attribute and then refer to that or is it much simpler? I looked at the local variables in the gas disturb microsolver but as far as I can tell they all refer to the simulation step time which is in the beginning of the whole simulation. Some help ore pointers are really appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Navneet Arora Posted February 6, 2017 Share Posted February 6, 2017 you need to mask your turbulence field with the age field, search on odforce for creating age field . Quote Link to comment Share on other sites More sharing options...
