can you specify a bit more?
that error is common when you render in a farm.
check that the path pointing to the houdini executable is the same version that your houdini version
 for example if you are using houdini 15.5.xx
the path must be:  c:/program files/side effects software/houdini 15.5.xx (full version number)/bin/hython.exe.
