nigelgardiner Posted February 27, 2017 Share Posted February 27, 2017 Hi there Is there a way to save to disk in background if I'm saving my geo files via two separate file cache nodes. Currently I merge them together and have to play the sim in order for them to save but it would be a lot better if I could save to disk in background. Any advice much appreciated. Thanks Nigel. Quote Link to comment Share on other sites More sharing options...
trzanko Posted February 27, 2017 Share Posted February 27, 2017 (edited) Pretty sure you can render to disk in background in multiple file caches. Though you'd have to set some stuff up to get them to start at the same time. There are a few ways to achieve the desired result: You can merge them both into one stream and group them before inputting to a file cache and save to disk in background. When you read the file you can blast the different groups into their own stream. Create a macro control null and reference the render to background button from each file cache to the null and you can launch them all from there. You can make multiple ROP output drivers in sop context and in the ROP context fetch them both, merge them and you can render them both. Save and open a new file, work in the new file while the other one cooks. Hope I'm understanding your question and I hope this helps! Edited February 27, 2017 by trzanko Quote Link to comment Share on other sites More sharing options...
nigelgardiner Posted February 27, 2017 Author Share Posted February 27, 2017 Hey Trzanko Yep, that's what I meant. If I understand you correctly I can group my data coming from the separate dop i/o nodes, merge them and save out via one file cache or something loosely similar? Thanks for your help and thanks to whoever invented timezones. cheers Nigel. Quote Link to comment Share on other sites More sharing options...
trzanko Posted March 3, 2017 Share Posted March 3, 2017 Yea, group each object separately, merge them, file cache, and then when you read it you can then blast by group Quote Link to comment Share on other sites More sharing options...
WLVL Posted October 10, 2024 Share Posted October 10, 2024 another way could be parallel caching, this become very efficient especially when the 2 streams that you are merging are particularly heavy, and you want to load the 2 independently. this would also save time for any upstream shared operations as it will have to cook them just once, while caching in 2 different file on disk (learned this trick from one of my Houdini heroes) parallel_caching.hip Quote Link to comment Share on other sites More sharing options...
