markerline Posted June 27, 2005 Share Posted June 27, 2005 Dear users: I am trying to create a set of faces based on points that are not connected. The points exist in 3d space and were based on previous, slightly different, geometry. I don't want to select each point in the viewport individually and create faces this way. I want to use a SOP to automatically create faces for me. Can this be done? I tried using polyloft but so far this doesn't work. Thanks for any help. sincerely, penciline Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted June 27, 2005 Share Posted June 27, 2005 penciline said: Dear users:I am trying to create a set of faces based on points that are not connected. The points exist in 3d space and were based on previous, slightly different, geometry. I don't want to select each point in the viewport individually and create faces this way. I want to use a SOP to automatically create faces for me. Can this be done? I tried using polyloft but so far this doesn't work. Thanks for any help. sincerely, penciline 19068[/snapback] Huh... Are you trying to create poly faces from a point cloud...? I am not entirely sure if I understand about automatically create faces part, but otherwise, there's polyknit SOP that might be what you're looking for perhaps? Quote Link to comment Share on other sites More sharing options...
markerline Posted June 27, 2005 Author Share Posted June 27, 2005 TheUsualAlex said: Huh... Are you trying to create poly faces from a point cloud...? I am not entirely sure if I understand about automatically create faces part, but otherwise, there's polyknit SOP that might be what you're looking for perhaps? 19070[/snapback] Yes, I'm trying to make a surface based on a point cloud. Is polyknit what I need? -penciline Quote Link to comment Share on other sites More sharing options...
sibarrick Posted June 27, 2005 Share Posted June 27, 2005 or the add sop. But both require some user input they aren't automatic. Quote Link to comment Share on other sites More sharing options...
