Render several takes not working
I tried to figure it out by myself, but don't get it. I've read that you either need to merge all ROPs and render the merge node or connect all ROPs and render the last one. Neither works. It always renders the first take and then stops.
I render print res with the Indie version, so "render current frame" is the only option in terms of choosing which frame I want to render. I use Redshift.
Did anybody encounter similar problems? Running to the PC every few minutes and check whether one can manually start rendering the next take is not a real life option (though the only one which currently "works").
Cheers
Tom
