rangok Posted March 27, 2017 Share Posted March 27, 2017 How can I use an attribute that I have created on a Detail level to drive a specific parameter in the SHOP network? Right now my Attribute create gives me a height attrib for this unit which = 180 and should make the hue shift turn my object blue... doesn't seem like it is working because it is still the red/purple color... any idea on how I can fix this ??? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 27, 2017 Share Posted March 27, 2017 Why do you use the @ symbol? You always need to import an attribute with a parameterVop. Quote Link to comment Share on other sites More sharing options...
rangok Posted March 27, 2017 Author Share Posted March 27, 2017 not sure what I am doing . just started with Houdini recently . can you tell me how I could do that? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 27, 2017 Share Posted March 27, 2017 tab key - "bind" then in the Name field - type "height" - then you'll need to expose the parameter on the RS_ColorCorrect- click the 3 little lines icon - then connect the output of bind to the Hue Shift parameter. Quote Link to comment Share on other sites More sharing options...
