Replacing dop geo
This I am pretty sure has an easy solution but I didn't manage to figure it out myself.
I did a simple rdb grain sim and want to swap/copy the geo I use for rendering onto the points I fetch from simulation.
My current method is to use a test object I want to copy with a copytopoints that is connected to a dopimport node. (Set to: Fetch packed geometry from dop network + display as centroid).
Now this works for the most part. My test object is copied onto the points and follows the rotation and movement. But the issue I am having is that it doesn't take into account the initial rotation value and that the test object is not lining up with all of my simulation geo.
Hopefully what I am after at least makes some sense with the file provided.
replace_grain_odforce_upload.hiplc
