point SOP, old vs new, stuck following tutorial
lalamax3d
Hi Everyone.
while following a simple tutorial from Sir, Rohan Dalvi, i got stuck at point SOP. where he put color in vertices via bounding box. attached image shows his settings ( old point operator ) vs my attempt. any ideas. huge thanks in advance
$BB[X-Z] are local variables defined on old Point nodes. They evaluate to point positions relative to bounding box of the input. For $BBY case, lowest point is 0.0, highest is 1.0, in-between points got values between 0.0 and 1.0. Since Attribute Expression (aliased as Point node in Tab-menu) uses VEX, this will be VEXpression equivalent of $BBY:
relpointbbox(0, @P).y
There is no local variables on Attribute Expression node documented. Using local variables from old Point node will not work.
bby_alternative.hipnc
Edited by f1480187
