lalamax3d Posted April 12, 2017 Share Posted April 12, 2017 Hi Everyone. while following a simple tutorial from Sir, Rohan Dalvi, i got stuck at point SOP. where he put color in vertices via bounding box. attached image shows his settings ( old point operator ) vs my attempt. any ideas. huge thanks in advance Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 12, 2017 Share Posted April 12, 2017 (edited) $BB[X-Z] are local variables defined on old Point nodes. They evaluate to point positions relative to bounding box of the input. For $BBY case, lowest point is 0.0, highest is 1.0, in-between points got values between 0.0 and 1.0. Since Attribute Expression (aliased as Point node in Tab-menu) uses VEX, this will be VEXpression equivalent of $BBY: relpointbbox(0, @P).y There is no local variables on Attribute Expression node documented. Using local variables from old Point node will not work. bby_alternative.hipnc Edited April 12, 2017 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
lalamax3d Posted April 14, 2017 Author Share Posted April 14, 2017 thanks, i just checked, confirmed with source, add point node after and Cd to verify huge thanks again for source. Quote Link to comment Share on other sites More sharing options...
