Jason M Posted May 6, 2017 Share Posted May 6, 2017 (edited) We need a Volumetric Smoke Explosion similar to the first one in this video… It is to be placed into a simple motion graphic piece (replacing the Shutterstock footage)… https://vimeo.com/216282325 password - smoke We need it early Sunday 7 May (Sydney, Australia time). Very soon. A more detailed brief is below. Please email if you are available. Thanks. info@jasonmarshall.com.au +61 407 045 482 (Australia) Brief… As you can see in the WIP video, there are 2 base colours.. orange & purple. Please supply… 1 x Volumetric Smoke explosion that can be easily re-coloured in After Effects OR 2 x Volumetric Smoke explosions… 1 x Purple and 1 x Orange (see RGB values below) Orange (RGB values) R- 219 G - 129 B - 46 (Hex Value - #db812e) Purple (RGB Values) R - 115 G - 82 B - 157 (Hex Value - #73529d) The Volumetric Smoke explosion must start in the centre of the screen coming directly towards the camera. Smoke must look great on a white background. Must be supplied with a transparent alpha channel. Must be rendered at a high frame rate (50fps or higher) / slow motion so we can speed ramp it in After Effects. Duration (at normal speed) 7 seconds. (longer in slow motion) Dimensions up to 4K would be great but minimum dimensions are 1920 x 1080. Delivery time - WITHIN THE NEXT 24 HOURS We need it delivered early Sunday 7 May (Sydney, Australia time). Edited May 6, 2017 by Jason M Quote Link to comment Share on other sites More sharing options...
