ikoon Posted May 16, 2017 Share Posted May 16, 2017 (edited) I just made my first HDA I have also used custom Handle and Guide Geometry to easily animate and preview. I hope you will like it, but also you may experience some difficulties using it, as I am still newbie. My questions: The Ramp - adding new ramppoints and renaming the node itself is tricky ... please, how do you bind VOP to HDA? - problem is, that new points have relative path ch("../../linear1/values_ramp4value") instead of simple ch("../values_ramp4pos")HDAs: - please, is it good practice to save all my HDAs here? C:\Users\..user..\Documents\houdini16.0\otls // yes it is - I should add parameters only in the "Type Properties", right? Not in the "Edit Parameter Interface" // yes - is it good practice to have some string parameter "Output Attribute Name" and then use "Set Attribute VOP"? // yes, I am also experimenting with chs("") and then vex include with backticks VOPs: - is it better to use Get Attribute or the Import Point Attribute? Both work well. More here http://bit.ly/2s2TGLO - inside an IF block, I output values to Cd to preview them ... and even when the IF should be skipped, Cd gets default values // that is probably ok and inevitable, there is some slight performance loss, I will experiment with chs() and include linear.hdalcFetching info... Edited June 22, 2017 by ikoon questions answered 3 Quote Link to comment Share on other sites More sharing options...
ikoon Posted June 22, 2017 Author Share Posted June 22, 2017 Some time has passed, I have answered my questions above. I am also slowly rebuilding the HDA in vex, also to accept @attributes in the inputs, instead of just numbers. Please, I am still struggling with the ramp interface. There is a ramp inside HDA (on one VOP) and I promote that ramp to the HDA interface. It often happens (when unlocking), that the points on the ramp mismatch paths, new points have relative path ch("../../linear1/values_ramp4pos") instead of simple ch("../values_ramp4pos"). linear1 is the implicit name of the hda, similarly to box1... Please, do you have any bulletproof practice to promote ramps? Quote Link to comment Share on other sites More sharing options...
