HDA Input Signature's UI
So, unless I'm seeing it wrong there's no VOP Random node that allows you to input seed, offset and the two limits for the distribution. So I've decided to make one and tried to make it accept either integer or float in the Seed and Offset inputs, by using a signature.
One issue I noted though is that as the inputs data type change, the UI vanishes. Is there a way to address this so that as that change takes place I keep UI functionality?
Thanks
Edited by probiner
