Pivot Shift in RBD - SOLVED
kni8_2k
Hi, I wanted to know if anyone has encountered this problem.
I'm exporting rigid bodies from Houdini as Alembic to Maya, and noticed that when I convert that to Join animation in Maya there is a two frame shift at the beginning which puts all the pieces out of alignment
I then thought this was from the script, but looking at maya I saw that the pivot was moving on frame 1-3 then staying somewhat stable. after blaming this on Alembic(lol) I went back to houdini and found that if you switch the dop import node to create points to represent objects. you can see the shift happen with the picture using a trail sop.
This does not effect the actual sim geo, but is something that is happening on the underlying data. Which messes with conversion to bones.
Does anyone know how to prevent this  ? I've included a hip file. Thank you.
pivot_shift_example.hip
Edited by kni8_2k
