nDman Posted June 17, 2017 Share Posted June 17, 2017 (edited) Hi, I have some problems in H16. 1: When i try to make new object from shelf tools Houdini shows in viewport that i can use Shift key to move off it from the construction plane. But when I keep the shift key it actually scaling the object!! 2: In network editors the F shortcut don't frame the selected node! I checked the shortcut editor and The F is set for that but it not work! Are these bugs or they are changes in H16? Edited June 17, 2017 by nDman Quote Link to comment Share on other sites More sharing options...
ikoon Posted June 18, 2017 Share Posted June 18, 2017 Hi, see the attachments. Construction plane is off by default now. I have set F as Home selected for myself, too. 1 Quote Link to comment Share on other sites More sharing options...
nDman Posted June 18, 2017 Author Share Posted June 18, 2017 Thank you ikoon Quote Link to comment Share on other sites More sharing options...
