Flip fluid stick on collision
Hussein
i'm trying to make a honey simulation on a pancakes i have set everything except i dont know how to make the honey stick on the static object, i want it to keep falling but a thin layer of the honey stick on the pancakes anyone can help me to do this ?
i'm using Houdini 16
Edited by Hussein
  On 6/20/2017 at 12:55 AM, rbowden said:
Do you have Stick on Collision turned on in the fluid solver? Its located under Volume Motion---Collisions
Once  you turn that on, it should open up some options for you to control the sticking a bit more.
yea i found it but since i'm working on small scale sim the tweaking is too hard and rare when it stick
  On 6/20/2017 at 5:15 AM, marty said:
Turn on Viscosity, set it to 10, set Slip on Collision to 0.1
isn't slip on collision will make it more sliding ? cause i want it to stick  and if i did set to 0.1 it will have more sliding attribute than if its OFF.. am i right ?
I don't think honey is a perfect no-slip condition.
