breadbox Posted July 11, 2017 Share Posted July 11, 2017 Is there a way to convert a volume into a series of curve slices or sections similar to how the convertMeta "sections" node works for metaballs? I noticed there is a volume slice node, but it only works to create a mesh and not a curve. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted July 12, 2017 Share Posted July 12, 2017 Convert the volume to a mesh and intersect it with many Grids using the Boolean SOP. volume_to_slices.hipnc Quote Link to comment Share on other sites More sharing options...
breadbox Posted July 12, 2017 Author Share Posted July 12, 2017 ok boolean! going brute force, I like it. Only one small problem in some of the slices where there is a positive with a negative area its not creating a hole where it should. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted July 12, 2017 Share Posted July 12, 2017 Add Hole SOP. Quote Link to comment Share on other sites More sharing options...
breadbox Posted July 12, 2017 Author Share Posted July 12, 2017 perfecto much thanks Quote Link to comment Share on other sites More sharing options...
