$CEX $CEY $CEZ NOT WORK in v16.0504
hi, I try to centroid pivot of copied object but $CE command not work and got an error:
Error Unable to evaluate expression (Expression stack error (/obj/The_sim/copy1/tx)).
Error Unable to evaluate expression (Undefined variable (/obj/The_sim/copy1/px)).
Error Unable to evaluate expression (Undefined variable (/obj/The_sim/copy1/py)).
Error Unable to evaluate expression (Undefined variable (/obj/The_sim/copy1/pz)).
Tried centroid? Laziest way you can write it is centroid(0,0), centroid(0,1), centroid(0,2) for x y z. The tooltip that pops up says use a string for geo and then D_X, D_Y and D_Z but you can drop the string for 0 and the rest for 0 1 2.
  • Like 4
 thank you. it worked.
centroid("../The_Room",D_X)
