Texture Image Sequence in Mat Network
Hi everyone,
I want to load an image sequence via the Texture OP in a MAT network.
The syntax C:/myPath/img_$F.exr doesn't work directly.
The only way, I got it working was by containing the nodes in a Material Builder and promoting the path channel. Actually the old SHOP-like way. But this way is quite limiting to the possibilities of the MAT Network.
Is there a way to load image sequences directly in a MAT Network?
Edited by AlSk
