Blending 2 waves together
EuniceC
I have used the attribute VOP to create 2 separates wave deformers. I would like to blend these 2 together to get the shape that I want. I tried using different attribute nodes but I can't achieve the effect of blending the meshes together. How do I go about doing it?
I have attach my nodes network and the image here. You can clearly see that the meshes are separate, I want to combine the mesh. I tried joining the 2 attribute VOPs one after the other but that only increases its amplitude and nothing else, I want the 2 mesh to join at different position so I get a v shape effect like the png image I show here.
I thought of perhaps multiplying the 2 wave matrix together by using the attribute wrangle node but i'm not sure how to call out the VOP variables individually when both waves' output is the same (position P). Is there a better way to do this?
Any help and advice would be appreciated, Thanks!
Eunice
Edited by EuniceC
