highdensity Posted August 17, 2017 Share Posted August 17, 2017 hey guys, I imported a model with alot of small pieces from maya to houdini via alembic. i use arnold to render my stuff and to be able to view alembic geo when i render i need to set the "load as" parameter to load houdini geometry and "poly soup premitives" to no poly soup primitives on the alembic node.the problem is that i have 200+ nodes that i need to make the change to and i cant simply select all the nodes at once because they are not at the same level. is there a way to change the settings on all the node at once ? or should i post in the scripting categorie ? Quote Link to comment Share on other sites More sharing options...
Yon Posted August 17, 2017 Share Posted August 17, 2017 (edited) Use a wildcard in your filename to import all at once?.. Not sure if that will work.. But I think if you export your model as a single object with subgroups Houdini will find and build that hierarchy Theres likely a way to code a fix but it's easier to have not made the problem initially Edited August 17, 2017 by Yon Quote Link to comment Share on other sites More sharing options...
