seep, nurb backbone attributes dont come across to created geo..
locvio
If backbone is poly, attributes come across to geometry created by sweep
If they are nurb, resulting geometry gets '0'..
wondering if that's a bug, or expected..
thanks
Alex
help doesnt mention backbone nurb vs poly..
These point attributes and groups will be copied from the backbone points to the cross-section points. If a uv attribute is present on both the cross-section and backbone, and Cycle Type is set to either One Primitive at a Time or Cycle Primitives, only the u component will be copied from the backbone, so the v component will still be from the cross-section uv attribute. Although only point attributes are copied from the backbone, there is a special case for if the cross-section has a vertex uv attribute, point uv values can be copied into the destination vertex uv attribute, but this only works for uv.
