Thread PointVop Guidance
meldrew
Hi all,
I've started putting an asset together which allows me to create multiple 'threads' from a single line, then effect them as if they are fraying/weaving.
I'm quite happy with it, however my approach doesn't lend itself well to anything other than straight lines, and I'd like to apply it to more/multiple complex curves - so that it follows their contours exactly.
At the moment it does 'work', however it distorts the original curve quite a lot, which I'd like to avoid.
Could anyone suggest a way for me to adapt my current VOP setup to calculate the trigonometry per curve? Or an alternative to using the 'wireU' attrib?
Or alternatively, if there is a different approach I should be taking all-together? any pointers in right direction would be much appreciated :)
.hip attached - Thanks in advance!
(N.B. This setup is loosely based on a thread I originally found here on odforce some time ago - but I cannot for the life of me find it now, so a hat tip goes to OP if reading.)
thread_tool_asset_003.hip
Hi, if you want to have wires "circle" around the central wire (like a helix), then you may like these topics:
Probably the best for you:
http://forums.odforce.net/topic/25896-helix-along-curve/?do=findComment&comment=150443
With volumes, but you may use the "cross product" part of it:
https://vimeo.com/162213251
EDIT: the vimeo, at time 51:10 Simon is talking about the cross product
For inspiration also here, but eetu uses different principle, I personaly dont even know how eetu does it:
http://forums.odforce.net/topic/8471-eetus-lab/?do=findComment&comment=119237
Edited by ikoon
