Point Order
I'm trying to iterate over my points in the same way that houdini would.
so, i have a grid where I get the point list via
GEO_PointList points = getOutputGDP()->points();
And i can get my grid resolution via
GEO_Primitive* source_prim = getOutputGDP()->primitives()(0);
GEO_Hull* hull_surf = (GEO_Hull*)source_prim;
int resx = hull_surf->getNumRows();
int resy = hull_surf->getNumCols();
now its up to me to iterate the points via
for ( int y = 0; y < resy; y++)
for ( int x = 0; x < resx; x++)
int index = x + resx *y;
but this assumes that the data is ordered this way, and there are
3 other permutations to consider.
which way do I access my point data?
the reason why i'm accessing the array this way is so that I can
easily compare data from neighbouring points.
Is there a better way?
jeff
Hi Jeff,
Have you considered iterating through the hull itself? Each vertex on the hull can be indexed using row/column and then from the vertex you can grab the GEO_Point that is associated with it. You never have to know the index of the point. For example:
for (r = 0; r &lt; hull-&gt;getNumRows(); r++)
   for (c = 0; c &lt; hull-&gt;getNumCols(); c++)
        const GEO_Point *pt = hull-&gt;getVertex(r, c).getPt();
This way to access neighbouring points, its easy, to just change the index of the vertices.
Hope that helps,
George.
  George said:
Hi Jeff,
Hope that helps,
George.
20764[/snapback]
beautifull!!!
thats exactly what i needed
thanks George,
jeff
