Custom vex function with optional chramp input
ikoon
I would like to define custom vex function and use it in my wrangles.
It will just return interpolated 0-1 value, a fade in a time range.
My problem is, that I would like to define it in a duplicate way (and that I am too newbie to do it).
float fade(float actualtime, float fromtime, float endtime, string mode="linear")
float fade(float actualtime, float fromtime, float endtime, string mode="nameofchramp")
The mode="nameofchramp" ... I mean for example UI chramp name "my_bezier_ease_out".
Please, can the function read from "external UI" chramp? How should I define this duplicity in the custom .h/.vfl file?
I dont mind if I have to create the ramp manually.
We can't define default parameters for non-context functions from VEX, but it is possible to workaround this too.
float fade(float actualtime, fromtime, endtime)
    return 444;
float fade(float actualtime, fromtime, endtime; string ramp)
    return chramp(ramp, .5);
    if (ramp == "linear")
        return 444;
     return fade(actualtime, fromtime, endtime, "linear");
  • Thanks 1
