[QUESTION] How to properly add textures with alpha (png) to geometry?
neblina
Hello everyone! I've been following some tutorials and stumbled upon some introduction to UV Mapping inside Houdini, even utilising parameters from the geometry itself for live-updating later when tweaking it, which is awesome!
Sadly I only got it working when applying a normal jpeg as texture. It doesn't seem to work at all with a png as input.
Attached is the setup that worked well with a normal jpeg texture for a procedural road I'm working on. I followed the tutorial and apparently one should convert it to NURBS before UV mapping. For me that didn't work; choosing Mesh instead worked fine. I tried that same setup only swapping the files, in this case a those wire fences as png, but nothing is shown in my viewport, although no errors come up.
The UV Mapping part is actually working fine (I guess). Apparently I just can't setup the material (or texture) correctly. Am I missing something, or should I approach it differently?
Thanks in advance!
Edited by neblina
Okay, so I figured it out, kind of.
It took me forever to debug this, since it didn't make sense at all. Finally, since the texture was downloaded from the internet it had a random file name, and it's first character was a dollar sign ($), this was somehow interfering. I renamed and it worked fine, the .png texture shows as expected in the viewport.
I'm not aiming for rendering or anything, but I was curious to see how it looked if I tried. So bam, another issue. Apparently the alpha channel gets blacked out. and does not show through. See attached picture with side by side comparison from viewport and mantra rendering. I apologise if this is trivial, I'm just starting out with Houdini and couldn't find anything related to this.
Anyone knows what I should do differently to fix this? Thanks in advance!
