michaelb-01 Posted November 1, 2017 Share Posted November 1, 2017 I posted this on the SideFX forum but haven't had any response so I thought i'd try my luck here: I'm getting some unbalanced forces when using grains, its the same problem as described in the grains masterclass around 32:50. As Jeff says the solution is to disable constraint averaging and then insure all the internal forces add up to 1. I've done this but I still have an imbalance.. I wanted to check which forces are meant to add up to 1, in the video it implies that Internal Collisions + Clumping + Explicit Constraints = 1. However in the help document it mentions that Friction with Particles should be included as well. So should I set Friction with Particles, Internal Collisions, Clumping and Explicit Constraints to 0.25? ( Quote Link to comment Share on other sites More sharing options...
markfancher Posted January 7, 2018 Share Posted January 7, 2018 hey michaelb - I am having this same exact issue ... were you ever able to find a solution? Quote Link to comment Share on other sites More sharing options...
