Orientation Matrix Help?
Justin K
Hello all, I am trying to get a firm grasp of orientation matrixes: special thanks
1) to tokeru,
2) this site
3) and this page here https://www.sidefx.com/forum/topic/6679/ for helping me get a  grasp of how the copy sop works with N, Up, and Orient.
Im getting it slowly, but now Ive hit well, a road block lol.  I have attached an example file.  Basically here is what I have:
I have a curve , and am attaching other  lines to this curve using a copy sop.  These curves have a stamped random noise, a stamped random scale,
and most importantly, an orientation attribute that forces them to wrap around the line at the angle I specify.  :D
Thing is  I want to do to 2 more things to these lines.  I want to be able to control their angle or orientation away from the curve, and I also want to be able to skin geometry along the lines as well, having the geometry skinning hold up if I do any rotations.
Here is where it stands now (just head to attached if that makes it easier).   The following code is where I get my initial @orient info for the copy stamp.   I am using the transform within the copy sop to 'tweak things' (mostly likely the source of the problem).
Wrangle 1:
@rotter = float(@ptnum)/float(@numpt);   //the incrementally increasing angle I will use within my quaternion.   In the following vop sop I fit this value between 0 and 360-- then promote the attribute.
Wrangle 2 (after vop sop)
@angle = radians(@rotter);
vector axis = @N;       //this defines the main path (y axis?) of my line.  I tried  both @N --generated using polyframe tangent u, and just an arbitrary up vector (0,1,0)--both had issues
matrix3 m = ident();
rotate(m, @angle, axis);    //rotating around my specified vector
@orient = quaternion(m);   //promotion to usable attribute
It works great! Sort of. The way this is set up I have limited control over additional rotation, and cant control the axis during skinning.
If I set the vector axis to the normal, then with no rotation within the copy sop, the skinning works at first.  When I rotate it though, the tubes start to flatten (see attached).
Conversely, if I just use an Up vector (0,1,0), the skinning only works when there is not transform, and now the tubes point straight up!  Not what I want at all.
Ill point out that this transformation in Z within the copy sop is actually perfect for this secondary rotation control, of only the skinning would follow suit.
Okay!  My thoughts for a solution. I tried to build a new Up and N vector within the loop itself, but this did not seem to help.  Not sure if this is a precedence thing or what---after all the rules of the copy sop might not apply to skinning.  I then tried to generate a new orient attribute but this didnt work either.  I have a hunch that WAY back in time, my original orientation wrangle MIGHT need a bit more info.
Any pointers would be great!
Thank you
water_flower_v005_upl.hipnc
Hi, I checked out your scene and updated it.
Quote
I added two angle values for yaw and pitch, which were then used in a rotate() function sequentially.
Quote
You still had the @orient attribute passing through the Sweep SOP. Simply delete that and let the sweep use the PolyFrame's tangentu as N.
H16.5.268 Indie - water_flower_v005_upl_jeff.rar
I hope this helps!
I hope this helps!
thanks galagast.  That was incredibly intuitive and helpful (thanks for the notes within the file as well).
