Evan Peignet Posted November 27, 2017 Share Posted November 27, 2017 (edited) Hello guys ! I need a little help. I have a curve and I am trying to get secondary curves around it. And finally to convert it to geometry with polywire. I don't want my curves to interpenetrate or to twist. I scatter points into a circle. I give an individual attribute to each point. I copy them to the points of the curve. I tried polyframe and vex code to keep the orientation of the points along the curve. I manage to get it but now I see that my secondary curves twist at some points. I think that I should use quaternion as orient before the copy but I don't know how to use it. For the moment, I've got this in my wrangle before the copy : v@N = v@N ; vector tangentu = v@tangentu; vector up = set(0,1,0); vector side = cross(tangentu, up) ; v@up = side; v@side = side ; v@N = tangentu ; // p@orient = set(@tangentu.x, @tangentu.y , @tangentu.z, radians(90) ); At the end, I will use a polywire (and I don't want them to twist around my main curve). Do you have some ideas of how I can do this ? I join the scene to explain. epe_copyWithRotationAlongCurve.hipnc Edited November 27, 2017 by Evan Peignet Forgot to join the scene Quote Link to comment Share on other sites More sharing options...
djiki Posted November 27, 2017 Share Posted November 27, 2017 I modified your scene. Is this what you need? epe_copyWithRotationAlongCurve_modified.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Evan Peignet Posted November 28, 2017 Author Share Posted November 28, 2017 Hey ! Thank you djiki, it works like a charm with the sweepSOP with Angle Fix and Fix Clipping activated. By curiosity, would you know how I could have done it with quaternion ? Have a good day ! Quote Link to comment Share on other sites More sharing options...
