edit parameter interface question
myra
i have a geo node and a object merge in side it
on the geo node
using edit parameter interface > from node tab > i can expose the object path attribute on the geo node
but what would be a way to add object path of the object merge on the geo node using python
Try:
node = hou.node('/obj/sphere')
# Copy parameter from object merge.
path_parm = node.parm('object_merge1/objpath1')
ptg = node.parmTemplateGroup()
ptg.append(path_parm.parmTemplate())
node.setParmTemplateGroup(ptg)
# Copy value to promoted parameter.
promoted_parm = node.parm('objpath1')
promoted_parm.set(path_parm.eval())
# Set parameter reference.
path_parm.set(promoted_parm)
