Sop solver previous frame data as attribute
Em_Fn
I am currently using a sop solver to update the position the position of some points based on the current position. I need to save the current position as a new attribute to calculate the distance between the new position and the current position.
My approach was to save the attribute out before I do the calculation, so that each position will be saved as an attribute before the calculation.
However, the doesn't seem to work
I did :
v@prevPos=@P;
my calculation which is v@P+=@V*timestep;
v@nextPos=@P;
as you can see, the @prevPos in frame 2 should equal to @P in frame 1, but it doesn't?
5a5e3fc8f0fe3_Screenshotfrom2018-01-1618-07-56.thumb.png.5ba6609f80ecee12faacd68d46e2918c.png5a5e3fc6f0b79_Screenshotfrom2018-01-1618-07-53.thumb.png.5d8366c4426644d745667cd0682c3cb7.png
There might be an easier way to do this; I would love to see one.
The problem is that `v@prev_P` was being set on each substep, including the last one right before the frame is done, so `v@prev_P` is returning the value 9/10ths of the way along. In order to fix this, `v@prev_P` has to only be set on the first substep of each frame.
The expression to determine the step number looks like this:
`i@stepnum += int( rint( (1/(@TimeInc * steps) * steps) * @TimeInc ) );`
where `steps` is the number of substeps on the SOP Solver.
Next, I check if we're on the first substep of a frame:
`if(((i@stepnum - 1) % steps) == 1) {
    v@prev_P = @P;
The `i@stepnum - 1` is necessary because the SOP Solver is set to cook on creation frame.
I'm attaching an example file.
prev_P_example_substeps.hip
Edited by toadstorm
Thank you so much ! That solved my problem , caching the position every 10 substeps
I had to also add || @Frame == ch("../../../startframe") in order to get the position before the start frame, as I was using the intersect function and it was firing the ray from the origin to my starting positions.
