Justin K Posted January 29, 2018 Share Posted January 29, 2018 Hello! what is the correct syntax for correctly declaring an empty matrix3 in vex? Atypically most people just use matrix3 mat = ident(); Can I decalre a matrix the same way I would a vector or float? (I just want to see all my variables on the spreadsheet while working through some code ) Example @N = {0,1,0); @f = @ptnum; I can see these on the spreadsheet matrix3 mat = ident(): I cannot Also, what are the technical terms for one versus the other? -- local attributes (no @ symbol) versus global variables (@symbol)? Thanks! Quote Link to comment Share on other sites More sharing options...
coltonmil Posted January 29, 2018 Share Posted January 29, 2018 (edited) Hey Justin, To declare a 3x3 matrix the way you're trying to: 3@mat = ident(); 2@ for 2x2 and 4@ for 4x4. The technical terminology is attribute with the @ symbol, and a parameter when it's just within the snippet. Edit: here's a lot more info http://www.sidefx.com/docs/houdini/vex/snippets.html Edited January 29, 2018 by coltonmil Quote Link to comment Share on other sites More sharing options...
Justin K Posted January 30, 2018 Author Share Posted January 30, 2018 1 hour ago, coltonmil said: Hey Justin, To declare a 3x3 matrix the way you're trying to: 3@mat = ident(); 2@ for 2x2 and 4@ for 4x4. The technical terminology is attribute with the @ symbol, and a parameter when it's just within the snippet. Edit: here's a lot more info http://www.sidefx.com/docs/houdini/vex/snippets.html Thanks! Quote Link to comment Share on other sites More sharing options...
