Light shader respecting motion blur
Hi all,
I'm confounded by a scenario and I'm hoping that someone else might have run across this.  I have a light shader assigned to a Light Template object: let's call it myLight.  It behaves as expected for non-motionblurred frames.  But when I place it inside a subnetwork, put extreme motion in rotation and translation on the subnet, add a generic Light (spotlight) object to the subnet (at the same level as myLight), the generic light motionblurs properly but I get no motion blur my myLight's contribution.  Here is the poignant code and information that I can tell:
light
myLight()
    vector Plight = ptransform("space:light", Ps);
    Cl = max(0, 1-length(Plight*set(1,1,0)));
  • I am using Houdini 16.5 Mantra Raytrace mode.
  • I am using exclusively xformational motion blur, 2 motion samples.
  • I have the above light shader assigned to a Light Template object: myLight.
  • myLight and a generic Houdini spotlight live in a subnet that has extreme translation and rotation animation.
  • It behaves as expected for non-motionblurred frames, with and without rotational and translational transformations.
  • It looks exactly the same with motionblur turned on, but the light from generic Houdini spotlight motionblurs properly in the same render.
  • The vector version of the transformation, vtransform("space:light", -L);  Seems to respect the translation component of the motion blur. BUT NOT the rotation component.  So generally, myLight WILL motionblur, but not consistently in the right direction/magnitude.  Weird.
  • I have tried using the explicit path of the Light Template and to its containing subnet to see if I could jigger it.  And the results are exactly the same:
    • vector Plight = ptransform("/obj/mySubnet/myLight", Ps);
    • vector Plight = ptransform("/obj/mySubnet", Ps);
So I am wondering if I'm using the right transformation, the right variables, and if I am to add any special rendering intrinsics to the Light Template object to get the "space:light" transformation to respect the motion blur properly.  What am I doing wrong?
