NodeTypeCategory (i.e. how to read X,Y from <hou.X for Y>)
ikoon
tldr: I cannot work with this type of data <hou.NodeTypeCategory for Chop>  please could you post an example of the if statement?
I have to check, if the Network Editor is currently inside Sop, or inside Chopnet etc. My skills are not enough to make the if statement right. I tried to search, but everything failed.
So this is really wrong, just for example:
current_type = node.childTypeCategory()
compare_type = "<hou.NodeTypeCategory for Chop>"
if current_type == compare_type:
    print "I am inside Chopnet"
I made this working workaround, but if anybody has time, please could you fix the above statement?
current_label = node.childTypeCategory().label()
compare_label = "Motion FX"
if current_label == compare_label:
Preamble:
>>> node = hou.node('/obj/geo1')
<hou.NodeTypeCategory for Sop>
>>> cat = node.childTypeCategory()
Ok.
The "wrong" snippet compares object to a string representation, they are different. It prints "<hou.NodeTypeCategory for Chop>" because of its __str__ or __repr__ method:
>>> cat.__str__()
'<hou.NodeTypeCategory for Sop>'
>>> cat.__repr__()
>>> str(cat) == '<hou.NodeTypeCategory for Sop>'
True
>>> repr(cat) == '<hou.NodeTypeCategory for Sop>'
True
You can compare name (or label, like you did) with corresponding string. This is probably what most people will do:
>>> cat.name() == 'Sop'
True
You can compare Python objects directly, if you have one already or know how to make it. Here is couple of methods:
>>> hou.nodeTypeCategories()['Sop']
>>> hou.sopNodeTypeCategory()
>>> cat == hou.nodeTypeCategories()['Sop']
True
>>> cat == hou.sopNodeTypeCategory()
True
if node.childTypeCategory() == hou.chopNodeTypeCategory():
    # In ChopNet.
