Rotate Vector in Chops (Edit)
Justin K
Hey all,
Simple goal here, trying to rotate a vector (@N) around another (v@cross) in chops within a wrangle.  Im not sure what I am doing wrong.  Ideally I would like to import two vectors into the chop network-- @N and v@cross, rotate N by Cross, and then bring  the updated N vectors back into sops using a channel sop.  I've attached a file.
Thanks in advance!
Edit:  I should point out I am trying to use quaternion rotations
 I found this thread on the sidefx forums but havent been able to implement the attribute create method as was suggested
https://www.sidefx.com/forum/topic/31300/?page=1#post-145135
chops_rot_test_update.hipnc
Edited by JKeil
UPDATE-- it seems like there is a fairly easy way around this.
All you really need the chops network for is to perform operations on the angle, as opposed to the vectors by the angle.
You can then just kick out the angle and apply the quaternion rotation within a wrangle or a vop as you prefer!
See new scene file
wavyguy_testing3.hipnc
Edited by JKeil
