nadmai Posted March 15, 2018 Share Posted March 15, 2018 Hi, I'm a bit stuck on how to get point attributes working per point in a creep sop inside a foreach SOP. In the attached file I created 10 points at world origin, gave them an x_pos attribute that is the same for every point. I gave them a y_pos attribute that varies per point. I hooked in the attributes via a spare input on the creep sop (same behaviour observed via spare input or direct reference). The x_pos will work making all the points travel around the object but the y_pos does not. If I modify x_pos so that it is a unique value per point it stops working. Could someone help me to see what I'm missing please? creep_point_attrs.hipnc Quote Link to comment Share on other sites More sharing options...
Gorrod Posted March 15, 2018 Share Posted March 15, 2018 (edited) You're always just looking for the point with the point number 0 in your expression point("../pointwrangle1", 0, "y_pos",0) if you replace the 0 with a reference to the iteration of the for loop via the foreach_begin1_metadata1 node you can change it to this point("../pointwrangle1", detail("../foreach_begin1_metadata1/", "iteration", 1), "y_pos", 0) or with the spare input point(-1, detail("../foreach_begin1_metadata1/", "iteration", 1), "y_pos", 0) or, what i would do, since you're already only having one point when iterating through them in the for loop, is just not accessing the pointwrangle1, where you have 10 points, but rather the creep SOP inside the loop itself, where you only have the point 0 anyway. point(0, 0, "y_pos",0) creep_point_attrs.hipnc Edited March 15, 2018 by Gorrod Quote Link to comment Share on other sites More sharing options...
nadmai Posted March 15, 2018 Author Share Posted March 15, 2018 (edited) Ahhh, many thanks. I was confused because when you set a foreach to single pass the point num will always be shown as 0 so I thought the loop would always treat each new point in the loop as 0, but I didn't reference from the right place. Over complication! Edited March 15, 2018 by nadmai extra detail added Quote Link to comment Share on other sites More sharing options...
