single .py script to playbar.play() or playbar.stop() depending on playbar.isPlaying()
ikoon
I was using this simple script (with hotkey) for a while, but it is probably not right way to do it.
Sometimes the playbar gets "stuck" and play() command doesn't work. Even if I run hou.playbar.play() from the python shell. I have to push the UI play button then.
I assume, that a right way is to use eventCallback(), but I cannot make it work, too. Please, do you anybody have working script for that?
if hou.playbar.isPlaying() :
    hou.playbar.stop()
else :
    hou.playbar.play()
  • 3 weeks later...
  • 1 year later...
