Difference Between Nodes
Attribute transfer ... transfers an attribute between two geometries (2 input nodes), based on distance and other paraleters, while Attrib promote just promotes an attribute from one level to the other level of the SAME geometry (1 input), that is to say from points to upper level primitive (composed of those points :by average the values of th points or other method to be specified), or on the other direction from detail to primitive or points and so on...
19 hours ago, Manav said:
I am trying to make a tornado. I Have set it up but , when i am playing the simulation i cannot see the tornado growing . Here I am sending you my project
Setup_V8.hipnc
I will try to have a look at your file, but I will be very busy this week :-(
Anyway, if you are looking for a good tutorial on making tornado in Houdini, I encourage you to look at those FXPHD tuts :
https://www.fxphd.com/details/491/
https://www.fxphd.com/details/502/
Lots of good ideas to take away.
