bgazdi20 Posted November 5, 2005 Share Posted November 5, 2005 I am getting a few frames where chunks of my i3d's dissapear. Has anyone ever seen anything like this and know of an easy fix? http://studentpages.scad.edu/~bgazdi20/i3d_artifacts.mov Quote Link to comment Share on other sites More sharing options...
doc Posted November 7, 2005 Share Posted November 7, 2005 What version are you using? Try turing your variance down in your i3d ROP. Or just try turning compression off all together. In an effort to save space sometimes certain voxels get rounded down to 0. looks good by the way. Luca Quote Link to comment Share on other sites More sharing options...
doc Posted November 7, 2005 Share Posted November 7, 2005 This has nothing to do with the original artifact, but I thought it might be of interest. Not sure if you're doing this already, but if you stamp the metaballs weight attribute you can control the denisty. When I first started using i3d I was only scaling the metaballs, when I found out weight affected density things went a lot smoother. Luca Quote Link to comment Share on other sites More sharing options...
bgazdi20 Posted November 8, 2005 Author Share Posted November 8, 2005 Thanks for the reply, I'm stamping the weight when the particles die but not when there birthed, I bet thats the problem. I'm gonna do some more tests when I get back to a machine. Brian G Quote Link to comment Share on other sites More sharing options...
