Denting Dops
sfennell
Hi, new to houdini and I'm interested in trying to simulate denting metal, much like a car crash, and was wondering if Dops could do this? I was looking at the POP shape match example which sort of simulates a soft body in a dop network but I couldn't get the geometry to retain each of its shape changes. Does anyone have any ideas on how to acheive this sort of effect? I'd like to be able to simulate the gross motion of the vehicle, and then apply denting and crushing shape deformations based on that DOP simulation. Is it possible to do all in DOPS or will I have to combine techniques?
I investigated the sop deformer example and modified it so that the torus is falling on a ground plane and the metaballs and magnets are generated at the collision impact positions. This does in fact give me denting deformations during the dop simulation, although sometimes it creates strange dents. I was wondering if there is a more controlable way to deform the geometry other than metaballs? Occasionally the geometry tends to deform in slightly unpredictable ways, stretching out in some collisions instead of denting in. Does anyone know a technique to help achieve more predictable denting deformations?
22454[/snapback]
I tried using the ray sop to create dents that confromed to the impact object. Couldn't
get it to work though. But I really didn't put too much time into it, give it a go you might be able
to get it working.
