Pop Min Max Inputs
aracid
hey all
in VEX on the VEX Geom Operator, there is the min and max inputs setting
this is not available on the VEX particle Operator
is this on purpose ?
if so, how does one use the Import Attribute function if its looking for the op index :2 etc
other than coding it :-)
thanks in advance
:blink:
hey all
thanks in advance
:blink:
22870[/snapback]
<Guessing>
POPs are a special case. Unlike the other contexts, POPs are a sort of Feedback loop, where each POP grabs the input changes it and passes it along and doesn't store any data locally. (like sops)
</Guessing>
Can you just use a Collect POP to merge the inputs together then pass it into a VEX POP?
