How To Trun On Trace Displacement
thx.... howo to turn onn trace displacement in houdini 8 for prman?
23201[/snapback]
(I'll give the H7- way ... maybe H8 has a "better" solution)
On the object, go to the Render Tab and, in the Pre-Include put down the RIB snippet. I think it's something like:
Attribute "trace" "int displacement" [1]
Cheers!
  • 4 weeks later...
Hi ykcosmo,
In Houdini versions before 8, the renderman ROP has a "Visibility Trace" parameter that you can put the list of objects for which you want ray tracing. In Houdini 8.0, each object has a set of parameters that control the various rays to which it's visible. There is more detailed info here:
http://www.sidefx.com/index.php?option=com...iewtopic&t=5012
Take care,
George.
  • 3 weeks later...
