Using Pointrefarray
Ok so this is probably very easy but my C++ skills are still weak.
I want to loop through all the points connected to a specified point.
I'm using
void findPrimsUsingPoint(const GEO_Point *pt,
UT_IntArray &primlist,
GB_PointRefArray &prefarr,
unsigned int primmask=GEOPRIMALL);
and hoping that "prefarr" returns the connected points.
Assuming this is correct how do you loop through the points in a GB_PointRefArray? are there any built in macros for this, any pointers??
If this is not the best way to do it is there another function I could use.
cheers
Hey Simon,
Never used this, so I could be all wrong, but, from the class definition, looping should go something like this:
// prefarr  is presumably created by findPrimsUsingPoint() ?
// GB_PointRefArray prefarr(/*...*/);
for(unsigned i=0; i < prefarr.entries(); i++) {
   // convenience: GB_PointRef const reference (const optional)
   GB_PointRef const &pref = *prefarr(i);
   // convenience: GB_Primitive const reference (const optional)
   GB_Primitive const &prim = *pref.prim;
   //convenience: GB_Vertex const reference
   GB_Vertex const &vtx = *pref.vtx;
   //convenience GEO_Point const reference (assumes gdp available)
   GEO_Point const &vpt = *gdp->points().entry(vtx.getBasePt()->getNum());
   // now you can use the vertex's point in some expression (as long
   // as you don't change its value, since I declared it const)...
   UT_Vector3 p = vpt.getPos()  /* + ... blah, blah, blah ... */;
// may need some cleanup here depending on who owns prefarr (?)
Alternatively, I guess you could use the prev/next pointers and walk through the array as a list -- the above uses the indexing operator (i.e: the functor GB_PointRef const *GB_PointRefArray::operator()(unsigned idx) const; )
Again, I haven't actually used any of this, and I could have gotten one of the many levels of indirection wrong (ie: "." vs "->") -- I'm just going by the headers, so caveat emptor! :P
Cheers.
This line is giving me the same error as I was getting
term does not evaluate to a function taking 1 argument
I don't understand, according to the header it certainly should take 1 argument
const GB_PointRef	*operator()(unsigned idx) const
       return (idx < size) ? array[idx] : 0;
23752[/snapback]
Hmmm... I don't see anything wrong with that assignment (from the point of view of data types at least). You can try *(prefarr(i)) if you want, but dereferencing should happen after the function call, so I don't think it's complaining about that...
Could it be that something else is not being initialized properly?
The closure object would need a reference to the gdp, so its declaration should look something like
GEO_Closure closure(*gdp);
and maybe you need a properly constructed GB_PointRefArray, like
GB_PointRefArray prefarr(gdp,0);
If that last is true, then maybe prefarr is *not* being filled by findPrimsUsingPoint, but instead it's using it as a reference and only filling the prim list (?)
Got a bare-bones version to test?
I'm thinking you should try something like this inside the cook method:
UT_IntArray primlist;
FOR_ALL_GPOINTS(gdp,ppt) {
   closure.findPrimsUsingPoint(ppt,primlist,prefarr);
   cerr<<"PT: "<<ppt->getNum()
       << " ConnPrims: "<<primlist.entries()
       << " ConnPts: "<<prefarr.entries()<<"\n";
just to get some idea of what might be going on in there...
And again, the above is untested.
I've got it compiling now, but I haven't tested it yet. I'll let you know.
I change it to this
GB_PointRef const pref = *(*prefarr)(i);
which makes some sense
prefarr is a pointer so dereference it, then pass it i, then dereference the pointer passed back.
or
GB_PointRef const *pref = (*prefarr)(i);
works to
cheers, watch this space :)
or
23756[/snapback]
That only makes sense if prefarr is a pointer... I was assuming it was just a local object, as in
in which case the compiler shouldn't complain about
Anywhoo... whatever works :)
BTW: which compiler are you using (windoze's MSVC.NET ? )
Yup, my fault.
I was passing prefarr as a pointer, which I shouldn't have been.
Sorry missed that line in your original post.
Thanks again for all the help.
BTW: which compiler are you using (windoze's MSVC.NET ?)
yup
edit:
Also turns out prefarr doesn't get updated, it's just a filter.
Still I can use the returned primlist instead.
I probably have seen that paper before but never paid it the attention it deserved :)
What I'm doing is no where near as clever. I'm using using built in HDK functions to incrementally expand the source group and then checking back to the previous step to calculate the distance. It's therefore a little sensitive to the actually arrangement of edges, and won't be very accurate as you move far away from the source group.
I'll have a good look at that paper and see if I can do anything with it, maybe I can have an option to calculate accurate distances but at slower cooking speed.
