Seeing/reading Object Coordinates In Dops
peship
i'm guessing how you guys deal when you want to query object coordinates in DOPs ?
i cant see anything like standard T R S channels ( even for output data only purposes ) to can show me clearly where is my object located in the space, how is rotated, etc.
What are you doing when you want to read the position of RBD object and to use it for your own purposes ?
Thanks.
Have a look at the sample file for the Dynamics CHOP. This file shows how to extract transform information into CHOP channels. You can extract the same information using the dopoption expression function. For example:
echo `dopoption("/obj/dopnet1", "rbdobject1", "Position", "tx")`
will show the tx value for the object named rbdobject1 in the DOP Network /obj/dopnet1.
Mark
